Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
Prepare the Server
Caution
Caution  - Do not attempt to move the server alone without a lift. For a one-person installation, the components must be removed and a lift must be used. For a two-person installation, the main components must be removed and a lift is optional.
  1. Remove the server from the box.
    See Shipping Kit (Part Number 7069640).
  2. Remove all of the processor modules, the main module, the power supplies, and the fan modules from the server.
    Refer to the service manual for detailed instructions.
  3. Determine your next step:
    • For a one-person installation, place the server on a mechanical lift.
    • For a two-person installation, place the server on a mechanical lift if one is available.
  4. Remove the PCIe card carriers if there are PCIe cards that need to be installed.
  5. Install the server in the rack.
    See Install the Server.
Related Information
