Connect the Ethernet Network
Cables
The server has four RJ-45 network connectors
labeled NET0, NET1, NET2, and NET3. Use these ports to connect the
server to the network. The Ethernet interfaces operate at 100 Mbps,
1000 Mbps, and 10000 Mbps. See Rear Panel Components for
port locations.
Note - The Oracle ILOM sideband management feature enables
you to access the SP using one of these Ethernet ports. Refer to
the administration guide for your server for instructions.
Note - To achieve 1-GbE network speeds, use Category 6 (or
better) cables and network devices that support 1000BASE-T networks.
- Connect
a Category 5 (or better) cable from your network switch or hub to Ethernet
Port 0 (NET0) on the rear of the chassis.
- Connect Category 5 (or better)
cables from your network switch or hub to the remaining Ethernet
ports (NET1, NET2, NET3) as needed.
