Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
Install the Top Rear Braces
Before You Begin
The rear braces are labeled left and right as viewed from the rear of the rack.
  1. Install two cage nuts into the left rear rack post above the adapter bracket.
  2. Position the top left brace on the left rear rack post above the adapter.
  3. Insert and finger-tighten the guide pin in the appropriate hole for your server.
  4. Secure the brace with two M6 x 12-mm screws.
  5. Repeat steps 1-4 for the top right brace.
    image:Illustration showing how to install the top rear shipping braces.
