Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
USB Ports
Two USB 3.0 ports are located at the rear panel. Two additional USB 3.0 ports are located on the main module and are accessible from the front panel. See the location of the USB ports at Front Panel Components and Rear Panel Components. The USB ports support hot-plugging. You can connect and disconnect USB cables and peripheral devices while the server is running without affecting server operations.
Each USB port supplies 5V output at 500 mA.
image:USB pinouts
Pin
Signal Description
Pin
Signal Description
A1
+5 V (fused)
B1
+5 V (fused)
A2
USB0/1-
B2
USB2/3-
A3
USB0/1+
B3
USB2/3+
A4
Ground
B4
Ground
Related Information
