Go to main content
oracle home
SPARC T5-4 Server Installation Guide
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
SPARC T5-4 Documentation Library
Understanding the Server
Front Panel Components
Updated: July 2015
Document Information
Using This Documentation
Product Documentation Library
Feedback
Installation Task Overview
Server Overview
Rear Panel Components
Confirming Specifications
Physical Specifications
Electrical Specifications
Environmental Requirements
Airflow Precautions
Preparing for Installation
Shipping Kit (Part Number 7069640)
Shipping Kit (Part Number 350-1662-02)
Handling Precautions
ESD Precautions
Tools Needed for Installation
Prepare the Server
Installing the Server
Rack Compatibility
Rack Cautions
Stabilize the Rack
Rackmount Kit (Part number 7069640)
Rackmount Kit (Part number 350-1662-02)
Determine Correct Rackmount Hardware
Mark the Rackmounting Location
Install the Rackmount Hardware
Installing the CMA
CMA Kit (CMA Comb, Part Number 7069793)
Install the CMA Comb
CMA Kit (Multi-piece CMA, Part Number 7041990)
Install the CMA (Multi-piece CMA)
Installing the Shipping Brace Assembly
Determine Correct Shipping Brace Fasteners
Install the Top Rear Braces
Install the Bottom Rear Shipping Brace
Remove the Bottom Rear Shipping Brace
Install the Server
Connecting the Server Cables
Cabling Requirements
Identifying Ports
USB Ports
SER MGT Ports
NET MGT Port
Gigabit Ethernet Ports
VGA Port
Connecting Data and Management Cables
Connect the SER MGT Cable
Connect the NET MGT Cable
Connect the Ethernet Network Cables
Connect Other Data Cables
Secure Cables Using the CMA
Powering On the Server for the First Time
Prepare the Power Cords
Connect a Terminal or Emulator to the SER MGT Port
Power on the System for the First Time
Oracle ILOM System Console
Installing the OS
Configure the Preinstalled OS
Reach a State to Install a Fresh OS (Oracle ILOM CLI)
Reach a State to Install a Fresh OS (Oracle ILOM Web Interface)
Oracle Solaris OS Configuration Parameters
Assigning a Static IP Address to the SP
Log In to the SP (SER MGT Port)
Assign a Static IP Address to the NET MGT Port
Glossary
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index U
Index V
Index W
Language:
English
No.
Description
1
Power button
2
VGA port
3
SER MGT port
4
USB 3.0 ports
Related Information
Server Overview
Previous
Next
