Go to main content
SPARC T5-4 Server Installation Guide
Exit Print View
Updated: July 2015
Rear Panel Components
Note - You must follow the proper sequence when connecting cables to the server. Do not connect the power cords until all data cables have been connected.
image:Figure showing the rear panel components on the server.
No.
Description
Links
1
Power supply unit AC inputs
2
NET MGT RJ-45 network port
3
SER MGT RJ-45 serial port
4
Network 10GbE ports: NET0—NET3
5
USB 3.0 ports
6
VGA port
Related Information
