Network
Connection Requirements for Oracle SuperCluster T5-8
The following connections are required for Oracle SuperCluster T5-8 installation:
Table 1 New Network Connections Required for Installation
Management network |
1 for Ethernet switch |
Connect to the existing management network |
Client access network |
Typically 2 per logical domain. |
Connect to the client access network.
(You will not have redundancy through IPMP if there is only one
connection per logical domain.) |
