This switch is inside a vented filler panel in Unit 19 of your system rack. Note that you should not connect to any of the management or console ports on the switch. The ports are labeled on the switch.
The network properties screen is displayed.
The Internet Protocol (TCP/IP) Properties screen is displayed.
# ifconfig -a
The list of network devices or adapters attached to the system is displayed.
# ifconfig eth0 192.0.2.10 netmask 255.255.255.0 up
In this example, the ifconfig command assigns the IPv4 address 192.0.2.10, with a network mask of 255.255.255.0, to the eth0 interface.
Connect to one of the service processor IP addresses or to the IP address of a SPARC T5-8 server that is up and running.
