Caution - If the circuit breakers are in the On position, destructive sparking might occur when you attach the AC cables to the rack. |
Ensure that both PDUs are turned completely off.
PDU-A is at the left side of the cabinet. PDU-B is at the right. Each PDU has six switches (circuit breakers), one for each socket group.
Figure 22 Power Switches on PDU
1 Power switch lies flat in the On position.
2Power switch is tilted in the Off position.
The ties are for shipping only and are no longer needed.
