Go to main content
Oracle® SuperCluster T5-8 Owner's Guide
Exit Print View
Updated: May 2016
Enable HTTPS on ASR Manager (Optional)
If you need to use HTTPS for security purposes, you can set up HTTPS/SSL for the ASR Manager HTTP receiver.
  1. Once the SSL certificate from a trusted authority is loaded into keystore, then add the following SSL connector in /var/opt/SUNWsasm/configuration/jetty/jetty.xml below the <Call name="addConnector"> sections:
    <Call name=”addConnector”>
      <Arg>
        <New class=”org.mortbay.jetty.security.SslSocketConnector”>
          <Set name=”Port”>443</Set>
          <Set name=”maxIdleTime”>30000</Set>
          <Set name=”keystore”>path-to-keystore</Set>
          <Set name=”password”>password</Set>
          <Set name=”keyPassword”key-password</Set>
          <Set name=”truststore”>path-to-keystore</Set>
          <Set name=”trustPassword”trust-password</Set>
        </New>
      </Arg>
    </Call>
    Passwords above can be plain text or obfuscated as follows:
    java -classpath lib/jetty-6.1.7.jar:lib/jetty-util-6.1.7.jar
    org.mortbay.jetty.security.Password plaintext-password
    Then copy and paste the output line starting with OBF: (including the OBF: part) into this jetty.xml config file.
  2. Restart OASM.
    • On a system running Oracle Solaris, type:
      # svcadm restart sasm
    • On a system running Oracle Linux, type:
      # /opt/SUNWsasm/bin/sasm stop-instance
      # /opt/SUNWsasm/bin/sasm start-instance
  3. Verify the SSL setup by accessing the following URL from a browser:
    https://ASR-Manager-name/asr
