Go to main content
Sun Server X4-8 Service Manual
Exit Print View
Updated: March 2018
Tools and Equipment
Most server component removal and installation procedures can be performed without tools. However, to service the system, you need the following:
  • ESD mat and grounding strap
  • Anti-static wrist strap
You might also need:
  • No. 2 Phillips screwdriver
  • A system console device, such as one of the following:
    • PC or workstation with RS-232 serial port
    • ASCII terminal
    • Terminal server
    • Patch panel connected to a terminal server
