Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Transfers a file from a remote location to update a target.
load [-force][-o verbose][-script]-source URI[target]
where:
URI is the uniform resource indicator.
target is the target and path to act upon.
This Oracle ILOM command transfers information in a file from a remote location specified by the URI to update a target. If no target is specified, the current target is affected. Your user must have administrator (a) privileges to use this command.
This table describes the options to the load command and their purposes:
This example shows how to load a custom certificate file, server.pem, to the /SP/services/https/ssl/custom_cert target from the host at IP address 123.45.67.89 using the TFTP protocol with the load command.
-> load -source tftp://123.45.67.89/server.pem /SP/services/https/ssl/custom_cert Load successful. ->
