Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Queries InfiniBand fabric administration attributes.
saquery [-h][-d][-p][-N][-D][-S][-I][-L][-l][-G][-O][-U][-c][-s] [-g][-m][-x][-C ca_name][-P ca_port][-t timeout][--src-to-dst source:destination][--sgid-to-dgid source-destination][name|lid|guid]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
guid is the global unique identifier.
name is the query name described in this table.
This InfiniBand command performs the selected Subnet Administrator query. Node records are queried by default.
The saquery command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the saquery command and their purposes.
This example shows how to produce a node record dump of every LID in the InfiniBand fabric with the saquery command.
Note - The output in the example is a portion of the full output.
FabMan@switch_name->saquery NodeRecord dump: lid.....................1 reserved................0x0 base_version............0x1 class_version...........0x1 node_type...............Switch num_ports...............0x24 sys_guid................0x0021283a8980a0a3 node_guid...............0x0021283a8980a0a0 port_guid...............0x0021283a8980a0a0 partition_cap...........0x8 device_id...............0xBD36 revision................0xA1 port_num................0x0 vendor_id...............0x2C9 NodeDescription.........SUN DCS 36P QDR mnm 10.132.124.33 FabMan@switch_name->
saquery man page
