Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Resets a target.
reset [-script][target]
where target is the target and path to act upon.
This Oracle ILOM command resets a resetable target to default conditions. If no target is specified, the current target is affected. The -script option skips confirmation of the action and proceeds as if yes was specified. Your user must have administrator (a) privileges to use this command.
This example shows how to reset the custom SSL certificate with the reset command.
-> reset /SP/services/https/ssl/custom_cert Are you sure you want to reset /SP/services/https/ssl/custom_cert (y/n)? y Performing reset on /SP/services/https/ssl/custom_cert ->
