Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Sets the Subnet Manager routing algorithm.
setsmrouting fattree|minhop|list
This hardware command sets the routing algorithm of the Subnet Manager within the management controller. By default, the routing algorithm is Fat Tree, which is ideal for routing between spine switches. For routing between leaf switches, you might consider the Min Hop routing algorithm. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, subnet prefix, M_Key, and routing algorithm.
The setsmrouting command writes the value of engine to the routing_engine parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsmrouting command. See disablesm Command.
The setsmpriority command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the Min Hop routing algorithm with the setsmrouting command.
FabMan@switch_name->setsmrouting minhop Current SM settings: smpriority 0 controlled_handover FALSE subnet_prefix 0xfe80000000000000 M_Key 0xabbababe0001 Routing engine minhop FabMan@switch_name->
Switch Administration, setting the routing algorithm
