Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Inspect the InfiniBand Cable Hardware
Inspect the InfiniBand Cable Connectors or Transceivers
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Note - Refer to Switch Installation, assembling the optical fiber InfiniBand cables, for instructions how to assemble InfiniBand cables that require assembly.
Refer to Switch Installation, assembling the optical fiber InfiniBand cables.
Ensure that the L groove is up for the top row of receptacles, or that the L groove is down for the bottom row of receptacles.
Note - On some QSFP cable connectors, there is a retraction strap. Both the retraction strap and L groove indicate the reference surface for the connector. When installing QSFP cables in the top row receptacles (0A, 1A, 2A, and so on), ensure that the L groove and retraction strap are up. When installing QSFP cables in the bottom row receptacles (0B, 1B, 2B, and so on) ensure that the L groove and retraction strap are down. See Identify the InfiniBand Cable.
As you slide the connector in, the shell should be in the center of the QSFP receptacle.
Close hook-and-loop fasteners at bundles and securing hard points.
