Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Display information about targets, properties, and commands.
show [-d targets|properties|commands|all]|[-l 1|2|3...255|all][-o table][target][property property...]
where:
target is the target and path to act upon.
property is the property of the target to show.
This Oracle ILOM command displays information about targets, their properties, and associated commands. If no target is specified, information about the current target is displayed.
This table describes the options to the show command and their purposes:
This example shows how to display the Oracle ILOM user accounts with the show command.
-> show -d targets /SP/users /SP/users Targets: root ilom-admin ilom-operator for_Check test ->
