Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays size of topology.
checktopomax [-h][-l][-v]
This hardware command is a script that verifies if the number of switches and HCAs found in the InfiniBand fabric is less than the maximum values of 48 switch chips and 1500 CAs.
The checktopomax command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the checktopomax command and their purposes.
This example shows how to verify the number of switches and HCAs within your InfiniBand fabric with the checktopomax command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@switch_name->checktopomax -v checktopomax: INFO: You have allowed max number of Switch elements to be 48 checktopomax: INFO: You have allowed max number of CA elements to be 1500 checktopomax: INFO: Number of Switch elements empiric found by application /usr/sbin/ibnodes: 2 checktopomax: INFO: Number of Ca elements empiric found by application /usr/sbin/ibnodes: 7 FabMan@switch_name->
