Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Defines fabric elements monitored through the FabricMIB.
fdconfig subcommand [-h]
This hardware command has subcommands that determine its functionality. This table describes the subcommands and provides their syntax.
where:
name is the host name of the element as configured by Oracle ILOM.
IP_address is the IP address of an element.
type is the identifier of the type of element:
sw36 – Sun Datacenter InfiniBand Switch 36.
sw36gw – Sun Network QDR InfiniBand Gateway Switch.
role is the purpose of the element:
gateway – The element acts as a gateway.
spineSwitch – The element acts as a spine switch.
leafSwitch – The element acts as a leaf switch.
unknown – The role of the element is unknown.
This hardware command configures a list of InfiniBand devices expected to be in the fabric. The Fabric Director node list file is used by the Fabric Directors to compile fabric MIBs that describe the InfiniBand fabric. For the file, InfiniBand devices are referred to as elements, and each internal element hosts a Fabric Director. Elements are switch chips with these roles:
gateway
spine switch
leaf switch
By default, Fabric Directors run in nonmaster mode. Only when a fabric element's Subnet Manager becomes the master Subnet Manager, does the fabric element's corresponding Fabric Director become the master Fabric Director.
This table describes each of the columns of the output.
The fdconfig command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the fdconfig command and their purposes.
This example shows how to list the current fabric configuration with the fdconfig command.
Note - The output for your InfiniBand fabric will differ from that in the example.
FabMan@switch_name->fdconfig list-current-fabric-config Name IP Addr Type Role(s) isMaster Fabricname -------------- ---------------- ------ --------------- -------- ---------- primary 123.45.67.89 sw36gw gateway test secondary 123.45.67.90 sw36 leafSwitch no test FabMan@switch_name->
