Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Queries InfiniBand fabric management attributes.
smpquery [-d][-D][-e][-G][-h][-v][-V][-C ca_name][-P ca_port][-t timeout] op lid|dr_path|guid [params]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
op is the supported operation.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
params is the parameter of the operation.
This InfiniBand command permits a subset of the standard SMP queries, including these:
Node information
Node description
Switch information
Port information
Output is in human-readable format.
Supported operations and parameters are as follows:
nodeinfo addr
nodedesc addr
portinfo addr [portnum]
switchinfo addr
pkeys addr [portnum]
sl2vl addr [portnum]
vlarb addr [portnum]
guids addr
where:
addr is the address.
portnum is the port number.
The smpquery command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the smpquery command and their purposes.
This example shows how to display node information for LID 1 with the smpquery command.
FabMan@switch_name->smpquery nodeinfo 1 # Node info: Lid 1 BaseVers:........................1 ClassVers:.......................1 NodeType:........................Switch NumPorts:........................36 SystemGuid:......................0x0021283a8980a0a3 Guid:............................0x0021283a8980a0a0 PortGuid:........................0x0021283a8980a0a0 PartCap:.........................8 DevId:...........................0xbd36 Revision:........................0x000000a1 LocalPort:.......................0 VendorId:........................0x0002c9 FabMan@switch_name->
smpquery man page
