Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Maps between switch chip ports and QSFP connectors.
dcsport [-guid guid|-type DCS-36p -ibdev ibdev] -port port|-connector connector|-printconnectors|-printinternal
where:
guid is the global unique identifier.
ibdev is the InfiniBand device name (Switch, Bridge-0-0, Bridge-0-1, Bridge-1-0, Bridge-1-1)
port is the number of the port (1 to 36).
connector is the name of the connector (0A to 17A, 0A-ETH, 1A-ETH, 0B to 17B).
Note - The subordinate names of the 10GbE connectors, 0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4 are also valid connector names.
This hardware command displays the mapping between I4 switch chip ports, BridgeX chip ports, and QSFP connectors. You can specify either a port or a connector. The command does not actually read the configuration of a switch or gateway, but deconstructs the mapping from a known model.
The dcsport command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the dcsport command and their purposes.
Note - If no guid or ibdev are specified, the command defaults to the local I4 switch chip or BridgeX chips, inferred by the port number or connector name.
This example shows how to display the mapping for connector 1A with the dcsport command.
FabMan@switch_name->dcsport -connector 1A Connector 1A maps to Switch port 22 FabMan@switch_name->
