Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Compares topology file to InfiniBand fabric.
matchtopology [-s systemname] topofile|[-h]
where:
systemname is the local system name in the topology file, should it be other than the host name.
topofile is the filename and path to the topology file used for matching.
This hardware command compares the topology file created with the generatetopology command with the current InfiniBand fabric topology. An error is displayed upon mismatch.
The matchtopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This table describes the options to the matchtopology command and their purposes.
This example shows how to compare the topology file to the current topology with the matchtopology command.
FabMan@switch_name->matchtopology AUG22.topo Topology matching will take some time. Please wait! -I--------------------------------------------------- -I- Topology matching results -I--------------------------------------------------- -I- The topology defined in topo1.topo perfectly matches the discoverd fabric. ---------------------------------------------------------------- FabMan@switch_name->
