Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Creates topology file.
generatetopology topofile|[-h]
where topofile is the filename and path to the topology file.
This hardware command creates a topology file of the InfiniBand fabric. This file is not compatible with the topology file created by the ibnetdiscover command. The generatetopology command is used with the matchtopology and showtopology commands to determine changes in the InfiniBand fabric. The -h option provides help.
The generatetopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to create a topology file called Topo.conf with the generatetopology command.
FabMan@switch_name->generatetopology AUG22.topo It will take some time to generate a topology file. Please wait! topo.conf file is created. Will now start generating the topo file Wrote Topology file: AUG22.topo FabMan@switch_name->
This is a portion of a topology file created by the generatetopology command.
Note - Your topology file will differ.
SUNIBQDRGW mnm34-98 Bridge 0 BX1/P1 -4x-10G-> I4_GENERIC mnm34-98 P4 -4x-10G-> I4_GENERIC mnm34-98 P3 BX3/P1 -4x-10G-> I4_GENERIC mnm34-98 P2 -4x-10G-> I4_GENERIC mnm34-98 P1 DEV26428_02P mnm34-55_HCA-1 P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-7A P2 -4x-10G-> I4_GENERIC mnm34-98 P33 SUNIBQDRGW mnm34-97 A-SW/P2 -4x-10G-> SUNIBQDRGW mnm34-97 BX3/P1 A-SW/P4 -4x-10G-> SUNIBQDRGW mnm34-97 BX1/P1 C-0B -4x-10G-> I4_GENERIC mnm34-98 P21 C-0A -4x-10G-> I4_GENERIC mnm34-98 P20 C-1B -4x-10G-> I4_GENERIC mnm34-98 P19 C-1A -4x-10G-> I4_GENERIC mnm34-98 P22 C-2B -4x-10G-> I4_GENERIC mnm34-98 P24 C-2A -4x-10G-> I4_GENERIC mnm34-98 P23 . . . DEV26428_02P mnm34-60_HCA-1 P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-8A P2 -4x-10G-> I4_GENERIC mnm34-98 P31 # Created from mnm34-98 at Thu Aug 19 13:32:25 PDT 2010
