Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays problematic components.
showunhealthy�
This hardware command shows a list of switch components that appear to have a problem. Unlike the env_test command, the showunhealty command only displays messages for components that have failed testing.
The showunhealthy command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display a list of unhealthy components in the switch with the showunhealthy command.
FabMan@switch_name->showunhealthy OK - No unhealthy sensors �FabMan@switch_name->
