Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Displays InfiniBand switch nodes in the topology.
ibswitches [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script the discovers the InfiniBand fabric topology or uses an existing topology file to extract the switch nodes.
The ibswitches command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibswitches command and their purposes.
This example shows how to display the switch GUIDs with the ibswitches command.
Note - The output for your InfiniBand fabric will greatly differ from that in the example.
FabMan@switch_name->ibswitches Switch : 0x0021283a8980a0a0 ports 36 "SUN DCS 36P QDR techpubs 10.132.124.33" enhanced port 0 lid 1 lmc 0 FabMan@switch_name->
ibswitches man page
