Go to main content
Oracle® Server X5-2 Installation Guide
Exit Print View
Updated: January 2021
Options for Accessing Firmware and Software Updates
Use one of the following options to obtain the latest firmware and software updates for your server:
  • Oracle System Assistant – Oracle System Assistant is a factory-installed option for some Oracle x86 servers that enables you to easily download and install the latest software releases.
    For information about using Oracle System Assistant, refer to the Oracle X5 Series Servers Administration Guide at https://www.oracle.com/goto/x86admindiag/docs.
  • My Oracle Support – All system software releases are available from the My Oracle Support web site at https://support.oracle.com.
    For information about what is available from the My Oracle Support web site, see Software Releases.
  • Other Methods – You can use Oracle Enterprise Manager Ops Center, Oracle Hardware Management Pack, or Oracle ILOM to update your server software and firmware.
    For information, see Installing Updates Using Other Methods.
