After you have completed the configuration worksheet, use the following procedure to configure the preinstalled Oracle Solaris operating system.
To power on the server, use one of the following methods:
From the Oracle ILOM web interface, select Host Management → Power Control, and then select Power On from the Select Action list box. Click Save, and then click OK.
From the Oracle ILOM CLI, type the following command from the prompt:
-> start /System
When prompted, type y to confirm:
Are you sure you want to start /System (y/n)? y
Starting /System
To reset the server, use one of the following methods:
From the Oracle ILOM web interface, select Host Management → Power Control, and then select Reset from the Select Action list box. Click Save, and then click OK.
From the Oracle ILOM command-line interface, type the following command from the prompt:
-> reset /System
Are you sure you want to reset /System (y/n)? y
The server begins the boot process.
From the Oracle ILOM web interface, select Remote Control → Redirection, and then click the Launch Remote Console button to launch video console redirection.
From the Oracle ILOM CLI, type:
-> start /HOST/console
Are you sure you want to start /HOST/console (y/n)? y
Serial console started.
After the server boots, the GRUB menu appears.
GNU GRUB Version 1.99 ,5.11.0.175.2.3.0.0.0 Oracle Solaris 11.2 SRU5 - Serial Port ttya Oracle Solaris 11.2 SRU5 - Graphics Adapter
You can choose whether you want to continue to direct the display to the serial output or direct the display to a device connected to the video port.
Use the information you collected earlier about your organization and network environment.
The screens that are displayed will vary, depending on the method that you chose for assigning network information to the server (DHCP or static IP address).
From the Oracle ILOM web interface, close the Remote System Console Plus window, and then log out from Oracle ILOM.
From the Oracle ILOM CLI, press Esc followed by the open parenthesis ( character (Shift+9), and then log out of Oracle ILOM.
