Oracle System Assistant is the preferred application for setting up your system software and firmware. Oracle System Assistant is an embedded, task-based server provisioning tool that enables you to perform initial server setup and maintenance for some Oracle x86 servers.
Using Oracle System Assistant, you can install a supported Oracle Solaris, Linux, or Windows Server operating system, install Oracle VM Server sofware, update your server to the latest software release, and configure server hardware.
Use one of the following methods to access Oracle System Assistant:
