Go to main content
Oracle® Server X5-2 Installation Guide
Exit Print View
Updated: January 2021
Rackmount Kit Contents
The rackmount kit contains two slide-rails, two mounting brackets, and optional securing screws.
Note -  Refer to the rackmount kit installation card for instructions on how to install your server into a four-post rack, using the slide-rail and cable management arm options.
image:Figure showing the contents of the tool-less rackmount kit.
Call Out
Description
1
Slide-rails
2
Mounting brackets
3
Four M4 x 5 fine-pitch mounting bracket securing screws (optional)
4
Installation card
Related Information
