Safety Checklist
Complete the following checklist to ensure that the safety requirements are met for the data
center in which the server will be installed.
Table 17 Safety Checklist
Is there an emergency power shut off?
Is there a fire protection system in the data center room?
Is the computer room adequately equipped to extinguish a fire?
Is antistatic flooring installed?
Is the floor below the raised floor free of obstacles and blockage?
