Standard system components are installed at the factory. Optional components that you purchased independent of the standard configuration are shipped separately, and in most cases should be installed before you install the server in a rack.
The following optional components can be ordered and purchased separately:
PCIe cards
DDR4 DIMM memory kits
Storage drives
Shipping bracket
If you ordered any options that are field-replaceable units (FRUs) or customer-replaceable units (CRUs), refer to the service label on the top cover of the server or the component removal and replacement procedures in the Oracle Server X6-2L Service Manual for installation instructions.
Supported components and their part numbers are subject to change over time and without notice. For the most up-to-date list, review the Oracle System Handbook by logging in to My Oracle Support at https://support.oracle.com. Select the Knowledge tab then among the Knowledge Links, select Oracle System Handbook. Within the handbook, click Current Systems, and then click the name and model of your server. On the product page that opens for the server, click Full Components List for a list of components.
Customers with service contracts can also access the Oracle System Handbook at: https://support.oracle.com/handbook_private/
