Server Physical Specifications
The following table lists the physical specifications for the Oracle Server
X6-2L.
Table 1 Oracle Server X6-2L Physical Specifications
Width
Server chassis
43.65 cm (17.19 inches)
Depth
Maximum overall
73.70 cm (29.02 inches)
Height
2-rack unit (2U) nominal
8.76 cm (3.45 inches)
Weight
Fully populated server
8-Disk Configuration
12-Disk Configuration
24-Disk Configuration
24.494 kg (54 lbs)
29.937 kg (66 lbs)
29.030 kg (64 lbs)
