Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
Software Architecture
The software follows a two-tier architecture model. It consists of two distinct layers: client and agent, as shown below.
image:Oracle VTS Architecture
Note -  Previous versions of the software supported a BUI interface. As of Oracle VTS 8.0, the BUI interface is no longer available. Instead, a GUI is provided. For instructions on using the BUI with earlier versions of the software, refer to the Sun VTS 7.0 Software User's Guide.
  • Client layer: Consists of the user interfaces for the software. Three different user interfaces are supported: the GUI, TTY, and CLI.
  • Agent layer: This layer consists of all the tests for testing the hardware, and a harness, which manages the tests. The harness also handles chores like the following:
    • Logging of messages
    • Handling of commands coming from different user interfaces
    • Updating status messages
    • Probing hardware
The harness (vtsk) acts as the control center for a testing session. The harness is the entity that controls and manages the complete working of a testing session. The harness performs functions like:
  • Starting and stopping tests
  • Handling commands from the user interfaces
  • Scheduling
Like the test, the vtsk process needs to be run on the machine under test.
Related Information
