Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
Display and Set Global Options (CLI)
  1. Type:
    ./vts_cmd get_global_options
    The global options that apply to all the tests are displayed. The parameters for the global options includes:
    • Duration of testing (in minutes)
    • Verbose option (enabled or disabled)
    • Duration of logging (in minutes)
    • Safe testing option (enabled or disabled)
  2. Specify a value for each parameter:
    ./vts_cmd set_global_options [Duration of Testing:<numeric value>,Verbose:<Enable or Disable>, Duration of Logging:<numeric value>, Safe Testing:<Enable or Disable>]
    You can determine the values from the options listed by the get_global_options command, as per testing requirements. A confirmation message with the word DONE in it verifies that the operation was successful.
    Note - If the operation fails (for example, an error due to format or a misspelled word), the following error string is displayed along with the usage help. Usage: ???vts_cmd set_global_options [Duration of Testing:<0-99999>,Verbose:Enable/Disable,Duration of Logging:<0-99999>,Safe Testing:Enable/Disable]'
Related Information
