Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
9-Pin to 9-Pin Port-to-Port Cable
Use these pin connections for 9-pin RS-232 and RS 423 port to 9-pin RS-232 and RS-423 port cables. Both plugs are male.
First Connector
Second Connector
Pins 1 and 6
Pin 4
Pin 2
Pin 3
Pin 3
Pin 2
Pin 4
Pins 1 and 6
Pin 5
Pin 5
Pin 7
Pin 8
Pin 8
Pin 7
image:9-Pin to 9-Pin Port-to-Port Cable Wiring Diagram
This cable has no part number assigned to it.
Related Information
