Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
Test Connector Overview
Connectors aid in testing I/O ports. The connectors take the form of either a single plug or a port-to-port cable with some communications connections shorted (loopedback).
Note - Connectors must be wired properly and connected firmly for the serial port tests to work correctly. Miswired, poorly soldered, or missing connectors can cause erroneous diagnostic error messages.
The following table depicts the pin assignments for most plugs and cables that you can use to test a system.
Table 3  Connector Pin Assignments
Signal Description
EIA
CCITT
RS-449A
RS-449B
DIN 8 8-pin round
DB9 9-pin
DB25 25-pin
Direction
Alpha ID
Chassis/Frame Ground
AA
101
1
NC*
NC*
NC*
1
None
AA
Transmit Data (TxDa)
BA
103
4
22
3
3
2
Output
BA
Receive Data (RxDa)
BB
104
6
24
5
2
3
Input
BB
Request To Send (RTSa)
CA
105
7
25
6
7
4
Output
CA
Clear To Send (CTSa)
CB
106
9
27
2
8
5
Input
CB
Data Set Ready (DSRa)
CC
107
11
29
NC*
6
6
Input/output
CC
Signal Ground (SG)
AB
102
9
NC*
4
5
7
None
AB
Data Carrier Detect (DCDa)
CF
109
13
31
7
1
8
Input
CF
Transmit Clock In (TRxCa)
DB
114
5
23
NC*
NC*
15
Input
DB
Receive Clock In (RTxCa)
DD
115
8
26
8
NC*
17
Input
DD
Data Terminal Ready (DTRa)
CD
108
12
30
1
4
20
Output
CD
External Clock Out (TRxCa)
DA
113
17
35
NC*
NC*
24
Output
DA
Secondary Data Carrier Detect (DCDb)
SCF
122
NC*
NC*
NC*
NC*
12
Input
SCF
Secondary Clear to Send (CTSb)
SCB
121
NC*
NC*
NC*
NC*
13
Input
SCB
Secondary Transmit Data (TxDb)
SBA
118
NC*
NC*
NC*
NC*
14
Output
SBA
Secondary Receive Data (RxDb)
SBB
119
NC*
NC*
NC*
NC*
16
Input
SBB
Secondary Request to Send (RTSb)
SCA
120
NC*
NC*
NC*
NC*
19
Output
SCA
*NC = No Connection
Related Information
