Oracle VTS application can be started with the script startsunvts. The script has a set of options that caters to different choices on how the application needs to be started. There are options to start the application and bring up a user interface that will need user intervention to select and start the tests. Also, there are options that will not bring up any user interface and start the testing without any user intervention.
The starsunvts script gets installed under /usr/sunvts/bin directory. You can type startsunvts in the terminal to know all the options. If you select any one the options from the menu (d,l,s,m, or A), it prompts the user to select yes or no to display the time taken for each LT in each pass.
# cd /usr/sunvts/bin # ./startsunvts Which VTS 8.0 User Interface (UI) or Testing option would you like to use? a) Command Line Interface b) Terminal User Interface c) Graphical User Interface d) Default Testing l) Comprehensive Testing s) Short Testing m) Memory Testing A) All level Testing s Do you want time information of each LT in each pass 'y/n' y Starting VTS Short Testing....
A more detailed description on startsunvts and its option is provided in the following sections.
