Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
Start the Software (Bootable CD/DVD)
  1. Insert the disk into the CD drive of the computer.
  2. Set BIOS to boot from the CD.
    To enable the CD to boot, ensure that the BIOS is configured properly. In the boot order priorities, the CD drive must be shown before the hard disk.
  3. Save the BIOS changes, and then exit the BIOS settings.
    The system boots from the CD and starts Oracle VTS. You are prompted to choose an interface: TTY, CLI, or GUI.
Related Information
