Oracle VTS 8.0 Software User's Guide
Exit Print View
Updated: January 2016
Reset a Test Session (CLI)
Once the session file is executed, you can use the reset_session command to restore the default values of the session without quitting from the application.
  • Type:
    ./vts_cmd reset_session
    A confirmation message with the word DONE in it verifies that the operation was successful.
Related Information
