Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Display Faulted System Components (Web)
Display the Switch Status LEDs States (Web)
Display the Aggregate Sensors State (Web)
Display Power Supply Status (Web)
Display Board-Level Voltages (Web)
Display Internal Temperatures (Web)
Display the Oracle ILOM Sessions (Web)
Display the Oracle ILOM Event Log (Web)
Checking the Status of Services (Web)
Display the HTTP Service Status (Web)
Display the HTTPS Service Status (Web)
Display the SSL Certificates (Web)
Display the SNMP Service Status (Web)
Display the SNMP Service User Accounts (Web)
Display the SNMP Service Communities (Web)
Display the IPMI Service Status (Web)
Display the DNS Client Status (Web)
Display the SMTP Client Status (Web)
Display the Network Time Protocol Servers (Web)
Verifying Other Aspects With Oracle ILOM (Web)
Display the Alert Properties (Web)
Display the Oracle ILOM User Accounts (Web)
Display the Remote Log Hosts (Web)
Display the Network Management Configuration (Web)
Display the CLI Session Timeout (Web)
Display System Component FRU ID (Web)
Display the Firmware Version (Web)
Display the Oracle ILOM Version (Web)
Display System Identification Properties (Web)
Performing General Tasks on Oracle ILOM Targets (Web)
Restart the Management Controller (Web)
Clear Faulted System Components (Web)
Clear the Oracle ILOM Event Log (Web)
Set the Remote Log Hosts (Web)
Configure the DNS Client (Web)
Configure the SMTP Client (Web)
Back Up the Configuration (Web)
Restore the Configuration (Web)
Create a Snapshot of the Switch State (Web)
Snapshot Dataset Information (Web)
Set the Network Management Parameters (Web)
Set the System Identification Properties (Web)
Performing Oracle ILOM User Tasks (Web)
Add an Oracle ILOM User Account (Web)
Change an Oracle ILOM User's Password and or Role (Web)
Delete an Oracle ILOM User Account (Web)
Disable the HTTP Service (Web)
Enable the HTTPS Service (Web)
Install a Custom SSL Certificate and Key (Web)
Remove the Custom SSL Certificate and Key (Web)
Disable the HTTPS Service (Web)
Configure the SNMP Service (Web)
Add SNMP Service User Accounts (Web)
Modify SNMP Service User Accounts (Web)
Delete SNMP Service User Accounts (Web)
Add SNMP Service Communities (Web)
Modify SNMP Service Communities (Web)
Delete SNMP Service Communities (Web)
Download SNMP Service MIBs (Web)
Disable the SNMP Service (Web)
Disable the IPMI Service (Web)
Enable Alerts to Send SNMP Traps (Web)
Enable Alerts to Send PETs (Web)
Enable Alerts to Send Email Alerts (Web)
Set the CLI Session Timeout (Web)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
