| Skip Navigation Links | |
| Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Display the Switch Chip Port to QSFP Connector Mapping
Locate an InfiniBand Device and Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
The output of some InfiniBand commands identify a node by its GUID. You can determine the switch chip or InfiniBand cable connection associated with that GUID using this procedure.
For example, given this output from the ibdiagnet command:
-W- lid=0x000f guid=0x002128312345c0a0 dev=48438 Port=21
In this example, the GUID is 0x002128312345c0a0 and the port is 21.
For example:
FabMan@switch_name->ibswitches Switch : 0x03ba01234567a0a0 ports 36 "SUN DCS 36P QDR mnm-36p-2 10.172.144.66" enhanced port 0 lid 1 lmc 0 Switch : 0x002128312345c0a0 ports 36 "SUN IB QDR GW switch mnm-gw-1 10.172.144.69" enhanced port 0 lid 15 lmc 0 FabMan@switch_name->
For example, GUID 0x002128312345c0a0 is truncated to c0a0.
From Switch GUIDs Overview, the c0 means that the node is inside of a Sun Network QDR InfiniBand Gateway Switch. The a means that the node is located in I4 switch chip A, the only switch chip. The port is 21.
For example, using Switch Chip Port to QSFP Connectors and Link LED Routes, I4 switch chip, port 21 routes to connector 1B.
Switch Reference, dcsport command
