| Skip Navigation Links | |
| Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
SUN-DCS-IB-MIB MIB OID Command Syntax
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Extended Port Counters Table OIDs
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Trap Configuration OIDs
Hardware Trap Configuration OIDs
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Understanding the ENTITY-MIB MIB OIDs
When you use the object identifiers in a command syntax, you must include the SUN-FABRIC-MIB MIB name. For example, using the V2c protocol:
$ command -v2c -c public mc_IP SUN-FABRIC-MIB::object_id argument
Or using the V3 protocol:
$ command -v3 -u snmp_user -l security_level -a authentication_protocol -A authentication_password -x DES -X privacy_password mc_IP SUN-FABRIC-MIB::object_id argument
where:
command is the command of the SNMP client that performs the action.
snmp_user is a configured user of the SNMP services.
security_level is:
authNoPriv – There is authentication, but no privacy.
authPriv – There is authentication and privacy.
authentication_protocol is either MD5 or SHA
authentication_password is the snmp_user's authentication password.
privacy_password is the snmp_user's privacy password.
mc_IP is the IP address of the management controller.
object_id is the object identifier, as listed in the right column of the tables.
argument is a combination of options and variables that support the object identifier.
For example, to securely display the IP address of the Fabric Manager:
$ snmpget -v3 -u usersnmp -l authPriv -a MD5 -A authpass -x DES -X privpass 123.45.67.89 SUN-FABRIC-MIB::fabricElemMgrIpAddress
