# prtdiag | grep 'System Config' # System Configuration:Oracle Corporation sun4v SPARC T4-4
/dev/fb link is correctly set up and pointing to the correct device
Xorg is running on the system
If the solaris-desktop package cannot be installed, then install the following FMRI packages:
