The Io_Interconnect test verifies all interconnects and different ASICs on the system board. If you enable unsafe testing, the Io_Interconnect test runs WriteRead tests. Unsafe tests cause data corruption on the hard disks and hence, should be enabled only if unsafe testing must be performed. For more information about Unsafe tests see Safe and Unsafe Options. The below sections describe the following.
