Exit Print View
Use these pin connections for female 9-pin RS-232 and RS-423 single-port plugs.
Test Connector Overview
25-Pin Port A-to-Port B Plug
25-Pin Port A-to-A Port B-to-B Plug
9-Pin Male Single-Port Plug
9-Pin to 9-Pin Port-to-Port Cable
NT to TE Cable
TPE Cable for Fast Ethernet
TPE Cable for Gigabit and 10/100 Ethernet
9-Pin Male DB-9 External Connector
9-Pin Female DB-9 External Connector
