Exit Print View
Using two standard RJ-45 connectors, connect pin 1 to pin 1, pin 2 to pin 2, and so on, for all pins. This is a straight-through connection.
Test Connector Overview
25-Pin Port A-to-Port B Plug
25-Pin Port A-to-A Port B-to-B Plug
9-Pin Male Single-Port Plug
9-Pin Female Single-Port Plug
9-Pin to 9-Pin Port-to-Port Cable
TPE Cable for Fast Ethernet
TPE Cable for Gigabit and 10/100 Ethernet
9-Pin Male DB-9 External Connector
9-Pin Female DB-9 External Connector
