If your system has a single I/O port to connect it to peripherals, use these connections to make a male 25-pin plug for that I/O port.
The following are the materials used for this plug:
PCR-E96FA (1)
PCS-E96LKPA (1)
3751 metal plug (1) (9563K42)
AWG28 Madison cable (8 in. long) UL/CSA Approved
