This mode provides system exercising capability. It tests the system with all its components. All tests are run in parallel. In this mode, no other application except this software should be running on the system. The characteristics of the tests in this mode are as follows:
Intrusive: The tests can be intrusive in nature. No other application should run on the system while these tests are running.
Data Safe: The tests are data safe by default.
Resource Usage: The tests are aware that there could be other tests running. Accordingly, the tests would then allocate and lock resources.
