# ./vts_cmd get_modesequencer_options
# ./vts_cmd set_modesequencer_options [Sequencer:Enable,First:<Test_Mode>,Second:<Test_Mode>,Third:<Test_Mode>,Loop:<Numerical_Value>]
Where:
Test_Mode: The test mode in which the Sequencer must run.
Numerical_Value: The number of times the sequence will run. This should be between 1 and 99999. By default this value is set to 1.
To set the Auto Mode Sequencer options, you must provide all the option parameters with a value as shown in the syntax. You can determine the values from the options listed by the get_modesequencer_options command.
A confirmation message with the word DONE in it verifies that the operation was successful. If the command fails, an error string is displayed along with the usage help
