Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Modifies a VNIC.
modifyvnic connector|lagname vnic_ID [-mac mac][-vlan vlan_ID][-n][-h]
where:
connector is the name of the connector (0A-ETH-1 to 0A-ETH-4 and 1A-ETH-1 to 1A-ETH-4).
lagname is the identifier of the LAG
vnic_ID is the VNIC identifier.
mac is the MAC address.
Note - Only even numbers are supported for the most significant byte of the MAC address (unicast).
Note - A VNIC must have a MAC address. If the VNIC is without a MAC address, assign one with the -mac option.
vlan_ID is the VLAN identifier (NO or 2 to 4094).
Note - Do not use VLAN identifiers 0, 1, or 4095. According to the IEEE 802.1Q specification, VLAN ID 0 is used for priority tag, and VLAN ID 1 is usually reserved for a switch or bridge management VLAN.
This hardware command enables you to modify a VNIC.
The modifyvnic command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
The following table describes the options to the modifyvnic command and their purposes:
The following example shows how to modify the MAC address for VNIC 9 with the modifyvnic command.
# modifyvnic 0A-ETH-1 9 -mac 02:02:02:02:02:08 VNIC ID 9 modified #
